crwdns2933307:0crwdne2933307:0
Changing Modes
The controller can be set in three modes: Switch, PC (X-input), and Android (D-input).
Switch mode is the default when connected to the Switch and Switch 2. It can be selected for PC use by holding the "Y" (left) button when powered on. It disables analog trigger input.
X-input mode is the default for PC use. It can be selected by holding the "X" (up) button.
D-input mode is the default for Android use. It can be selected by holding the "B" (down) button. It disables analog trigger input and rumble, but enables the back paddles as extra buttons.
Joystick Calibration Mode
To calibrate the joysticks you first have to enter calibration mode. Calibration mode is entered by holding L+R+Select+Start for 8 seconds. The same button combination is used to exit calibration mode.
During calibration mode, you must push the joysticks forward and rotate them clockwise three times.
8BitDo Ultimate Software
To configure the controller and update the firmware, you must use the 8BitDo Ultimate Software (Windows only).
The ultimate software let's you configure the buttons to your liking, set the deadzones of the joysticks and triggers, and configure the back paddles for X-input and Switch modes.
You can set three other controller profiles other than the default. The profiles are selected by pressing the "profile" button.
Adrián
crwdns2935283:001/22/23crwdne2935283:0
213 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 48
crwdns2936753:030crwdne2936753:0 151
crwdns2959996:0crwdne2959996:0 3,613
