Battery
crwdns2933313:01crwdne2933313:0 crwdns2934263:00crwdne2934263:0 |
How do I fix the rear window defrost |
One headlight not working |
Gear is stuck and not changing gears |
crwdns2935065:0crwdne2935065:0
crwdns2935077:02013, 2014, 2015, 2016, 2017, 2018 Jeep Wrangler (JK)crwdne2935077:0
Background and Identification
Jeep is an automobile company that was established in 1941. Jeep's cars were used by the United States Army throughout World War II. However, now Jeep automobiles are a common vehicle for the everyday American. They offer a variety of makes and models, many with off-road capabilities. The Jeep Wrangler is one such model.
You can use these repair guides for all Jeep Wranglers made between 2013 and 2018. A Jeep Wrangler has two doors and a Jeep Wrangler Unlimited has four doors. Within each Wrangler and Wrangler Unlimited there are different trims. The Jeep Wrangler X (Sport) has stock options. The Sahara edition has GPS navigation and larger rims and tires. The Rubicon edition has the same options as the Sahara. However, the Rubicon is adapted for rigorous off-road driving with a stronger front axle (Dana 44), mud terrain tires, and a (4:1) lower gear transfer case.
Specifications
- Make: Jeep
- Model: Wrangler
- V6 engine 3.6L Pentastar
- 285 bhp (213 kW; 289 PS) at 6400 rpm
- 260 lb⋅ft (353 N⋅m) at 4800 rpm
- Transmission:
- 5-speed Chrysler 545RFE automatic
6-speed Chrysler NSG370 manual - Seven Slot Grille
- Seats: 4 (2 door model); 5 (4 door model [Unlimited])
- Wheelbase:
- 2-door: 95.4 in (2,420 mm)
4-door: 116 in (2,950 mm) - Length:
- 2-door: 164.3 in (4,170 mm)
4-door: 184.9 in (4,700 mm) - Width:
- 2-door: 73.7 in (1,870 mm)
4-door: 73.9 in (1,880 mm) - Height: 70.9 in (1,800 mm)
2-Door Rubicon: 72.3 in (1,840 mm) - Curb weight: 3,760–4,340 lb (1,706–1,969 kg)
- Maximum Towing Capacity: 2000 lbs. (2 door model); 3500 lbs. (4 door model [Unlimited])
- 4 Wheel Drive
