Remove and install Ptu
How do I swap out a broken Ptu?
I asked FixBot (Ai) your question with its reply in Italics. Beware of Ai mistakes.
"How do I swap out a broken Ptu?'
This repair involves gravitational potential energy from working under a vehicle supported by jacks or lifts. If the vehicle is not properly secured, it can shift or collapse, resulting in severe crushing injuries or death. In many jurisdictions this requires a licensed professional. If you choose to proceed, here is what is involved.
Replacing the Power Transfer Unit (PTU) on a 2007–2014 Ford Edge AWD is an advanced, heavy mechanical job that involves removing the right halfshaft, exhaust components, and the PTU support bracket. The process requires unbolting the PTU from the transaxle and engine, with PTU mounting bolts torqued to 90 Nm (66 lb-ft) and support bracket bolts torqued to 70 Nm (52 lb-ft) upon reinstallation 1.
Because the procedure requires specialized powertrain lifting equipment and subframe alignment steps, consult the official factory service documentation for the complete illustrated removal sequence:
File
•Page 518•1,107 pages•37 MB
Let me know if you need help with a specific torque specification or component removal step.
Sources:
crwdns2959996:0crwdne2959996:0 30
