Desktop picture gets distorted
Whenever i touch the track pad of my MacBook13" (A1181) the desktop picture acts weird. It gets distorted and that happens only when i touch it, when i don't, it looks fine. Ive uploaded two states of that distortion. Any idea what it might be?
Update (11/15/26)
Ive uploaded here a video of whats exactly happening when im mooving the cursor.
If im not doing anything, there are no lines.
@genik - Yep micro-fractures within the LCD panel so the signals are messed up.
Think off it this way you have a loose light bulb in a ceiling light so it's lit but someone bounces on the floor so the light winks on and off as the connection makes and breaks. That's why you see the flicker. Here you only need to breathe! For it to break.
crwdns2957956:0crwdnd2957956:0 DanJ crwdne2957956:0 crwdns2950251:0crwdne2950251:0
Can it be some loose wire that’s not well connected?
crwdns2957956:0crwdnd2957956:0 genik crwdne2957956:0 crwdns2950251:0crwdne2950251:0
@genik - In a way that's Is the issue!
Within the LCD panel are metal oxide traces which the signals to the discrete Pixel cell turning it on and off. But it's not just that cell it's a column and row of cells. So the traces make and break contact as the panel moves.
So while the light bulb took a bit of a bounce to flicker, here it takes very little as the glass shifts ever so slightly and sometimes the neighboring line shorts across as well.
These lines are about as thin as your hair and are in the middle of the LCD sandwich so you can't fix them and besides that doesn't fix the root cause the rear glass panel has fractured.
Ok Dan, i get it. Do you think its worth buying and replacing the lcd or shall i just leave it?
@genik - It all depends on what your needs are as well as finding the part.
This is an older system which finding the part will take some doing! While the part will be somewhere around $200 USD for the full lid assembly used it's not that hard to replace. If you buy the LCD panel alone it's cheaper but there are harder to find and will require much more effort to replace.
Many people like these older systems because of the software they run. If that's not an issue getting a newer system even used might be the smarter direction.
