The Mercedes-Benz W126 is a series of S-Class automobiles manufactured by Mercedes-Benz between 1979 and 1992. Premiering in September 1979 as the successor to the W116 line, the W126 was the second generation to officially bear that prestigious designation, an abbreviation for the German Sonderklasse or "special class." The W126 was initially offered with straight-six, V8, and a turbocharged diesel engine for the sedan. A C126 2-door coupé versions was introduced in September 1981.
auto trans dip stick
I have an 84 merc 300sd. I can't get the locking cap on the trans dip stick to release so I can pull the dip stick.. I think it has a missing or broken part. I think there is supposed to be a lever that releases it. I just got the car so I'm not sure what the problem is. The cap will rotate and will pull up slightly but won't come out. Can I force it ? If so how? If I break it in the process of removing it, do you know where I can get a replacement? Thanks for your advise.
On an ’84 300SD, I wouldn’t force it yet. There is supposed to be a locking lever on that cap. The black piece underneath the red cap swings up and releases the clamp around the dipstick tube. Once that lever is released, the cap and dipstick should come out.
If that little lever is missing or broken, that may be exactly why you’re stuck. I’d look closely underneath the cap and see if there’s a small black hinged piece you can get a finger under. Don’t put a pair of pliers on the cap and start twisting it yet; it’s old plastic and you’ll probably just make the job more expensive.
There are replacement locking caps available, and Mercedes owners have been replacing these for years.
One other thing: once you get it out, check the end of the dipstick. These old Mercedes sticks can have the rounded end broken off, which can make the level markings misleading.
Where can I get a replacement? The only one I've found is in the UK and very expensive to ship. Where can i get one in the USA?
tom campbell crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 24
