Where is the backlight fuse located
I need to replace backlight fuse, where is it located.
If the motherboard is an MS-16V41 v1 then unfortunately I can't find a schematic for the board online or a free boardview file download but have found this supplier where you can purchase the boardview file for a small cost.
Usually fuses are marked either F or FV so look for that on the board. You may be unlucky as it could be located on the underside of the board, so the board will have to be removed to test it etc.
The boardview file should show its exact location
Also the file is a .cad format so you'll need a suitable program (example) to open it to view the file.
crwdns2942667:0crwdne2942667:0 26
