Repair, disassembly, and troubleshooting information for the Infinix Smart 8 Android smartphone, including model names Infinix X6525 and Infinix X6525D.
How to change display
Displays camera between in lagging
Hi Mavluda! If your Infinix Smart 8 display is lagging, try going into Settings, then Display & Brightness, and then Refresh Rate. Once there, select 90Hz instead of 60Hz if that option is available. The Smart 8 should support a 90Hz display, which is to make scrolling and animations smoother.
If it’s still lagging, I’d also try restarting the phone and closing some apps running in the background. If the lag happens even when you’re just navigating the home screen and settings, then it might be a software or hardware issue rather than the display setting itself.
Hope this helps!
Mavluda Eshonqulova crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 78
