This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
How do I fix obd code p0401
It appears that code is for insufficient EGR flow.
Some solutions are
  • Use a vacuum pump and observe if it opens. If it doesn’t, the valve may need to be cleaned or replaced.
    • Clean or Replace the EGR valve.
  • Check the voltage at the DPFE, compare to specified values (refer to a manual for your specific model)
    • Replace the DPFE sensor (with a good quality / OEM one)
  • Inspect all hoses and tubes connected to the EGR system for any blockages or leaks.
    • Clean or replace hoses as needed.
EDIT:
It appears you want to know how to replace the EGR valve Egr valve replacement escape
Dave O. crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 84
