Introduced in September 2004 and replaced with a version in 2010. The following model numbers apply: ZA11S, ZC71S, ZC11S, ZD11S, ZC21S, ZD21S, ZC31S.
Brake lights not working
Hi @arshmatharu
Check that the 15A fuse #18 in the engine compartment fuse box is OK.
If the fuse is OK check if the brake light switch which is operated by the brake pedal is OK. Here's a video that may help.
@arshmatharu besides the steps described in this answer, you can also download the WM for your Swift from this page 2004-2010 Suzuki Swift under the Documents Header. In the Brake chapter on page 474 you see where the stop light switch is located, how to adjust it and most likely to replace it. Page 1104 shows you how to test it.
Arsh Matharu crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 131
