Can I use my old iMac as an external display?
Hi there,
I have an old 24" "broken down" imac, and i would use is it as an external display for my new 21,5" i5 imac. Is it possible with or without modding the imac to use it as an external display?
i know that it isnt possible to use the origional displayport.
any help is welcome
As far as hardware goes, no. The LCD in the iMac gets its signal via the display data cable from the logic board. You can, however, use it as a display using software.
Since the connection depends on your wireless network, display performance may vary greatly.
You can also use a wired connection (Ethernet) Vs wireless (WiFi) as well. In any case your iMac needs to be working to make it a slave system to your other system (Master). ThunderBolt connections between systems could offer a better solution in the future if someone were to write the needed software. But again you have to have a working system.
Many thanks for the info so far.
ScreenRecycler is a nice solution but it is really slow, even over an ethernet connection. Other VNC's are even slower.
I just can't imagine the fact that it isn't possible to share video and also hardware info. (master/slave)setup.
koen kofflard crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,527
