Flashers randomly coming on
Hazard light are randomly coming on when parked. This then drains the battery.
Randomly activating flashers are usually caused by a faulty turn signal switch, hazard switch, or a wiring short. Start by checking for loose/corroded connectors and inspect the flasher relay. If the problem occurs when hitting bumps or turning the steering wheel, the switch or wiring is the most likely culprit.
crwdns2942667:0crwdne2942667:0 125
