Add a MBP Glass Display Bezel
I recently purchased a MBA Mid-2011 Model and was interested in the possibility of replacing (if required?) the aluminum display bezel with the MBP Glass Display Bezel (black border, glass cover).
I believe the dimensions are identical for the 13" models.
Would it be as simple as attaching the replacement bezel over the stock MBA, or are there tolerance concerns with the additional thickness when closed?
If not, is it possible to remove the aluminum bezel without removing the display from the body?
Any thoughts will be greatly appreciated...lets make a hybrid MBAP!
