The HTC Desire HD is an Android smartphone by HTC Corporation.
How to fix the volume buttons?
Hi to all, I need to fix the volume buttoms. Those that are on the left side of DHD. When I push over button - it works fine....but, on the contrary, the button + is hardly demage. I must push strongly and sometimes it doesn't work and sometimes it work. If I give an attention look to this volume buttons bar, I can notice that the volume button + is more inside the DHD than the other one.
So Can I fix it or Have I substitute the bar?
How could I do it?
Thanks in advance
MAx
I had a similar issues with the volume button on my inspire (same as dsire hd). I took it apart to check the volume flex cable and the upper part of the cable had a slight rip. I went to this link and ordered a new one, popped it in and it worked fine.
http://www.repairsuniverse.com/htc-desir...
yours sounds like it could also be an issue with the physical button as well. I would open it up and take a look.
Maybe you just need to buy a new button piece: http://www.htcrepairparts.com/volume-key...
If your HTC 7 trophy mobile phone volume keys not working then 1st check buttons,
if thy are ok but problem still then make Jumpers red line make jumper
HTC 7 Trophy Volume buttons not working
HTC 7 Trophy Volume buttons problem
HTC 7 Trophy Volume buttons problem solution
HTC 7 Trophy Volume key
http://repairphone24.blogspot.com/2014/1...http://repairphone24.blogspot.com/2014/1...
Massimo Sgroi crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 27,246
