Keyboard is typing the wrong character.
My keyboard on my MacBook keeps typing a Nordic symbol å instead of the letter a. Also, the delete key is deleting whole words instead of just one letter. I cannot get any help from Apple support. This just started out of the blue, I didn't change anything, I was typing an email and about half way through, all of a sudden I am getting this å everytime I type the letter a. Upgraded to snow leopard, but that didn't help either. Help!
Update (12/04/2013)
I have never resolved the issue, and have stopped using the Mac. It appears that this is a hardware issue not a software issue, Sorry I can't be of anymore help.
crwdns2944067:07crwdne2944067:0
Does this occur in all applications text, mail, web form boxes or just the mail client?
It is happening in all applications. I can use the virtual keyboard just fine, it is just a pain.
If at all anyone gets this problem. Try opening the laptop, disconnect the keyboard from the motherboard (the connector is always near the battery try), by this I dont mean the whole keyboard, just the connector. Then wipe the connector with a clean piece of cloth then re insert it again and then switch on the laptop. The keys should be working fine. Its the connector that confuses the keys either because there is dirt or loose connection. All the best.
So..... The quickest fix for this is to do a restart and shift R. It fixes common issues that reside within the OS. If your mac is ever working poorly, try this first.
Rick Hayes thank you! After messing with every keyboard setting this is what fixed the issue.
crwdns2934275:02crwdne2934275:0
crwdns2933315:07crwdne2933315:0
Go under the Apple in the upper left and corner to System Preferences > Language and Text and set it to English.
I have done that prior to posting here, the only keys affected by the issue are the a key and the delete key.
System Pref > Keyboard > Change Keyboard Type > Select JIS
@mayer thank you!!! Still relevant in 2020 :)
@kelwa if this answer helped you please vote it up
I've run into this problem a few time in a school full of iMac computers. Randomly someone can't logon and the keyboard appears to type some sort of unrecognized characters. I've discovered that a simple fix is to merely RUB MY HAND VIGOROUSLY OVER ALL THE KEYS. Voila! Working again. If there was a key that was stuck that I couldn't see, rubbing over all of them made it work again.
crwdns2889612:0crwdne2889612:0 9
crwdns2944067:07crwdne2944067:0:
I don't have an alt key...the above suggestion worked for me. To rub vigorously over all the keys. I apparently had one stuck. This immediately fixed the issue. Thanks @butchgibson
Great solution! This did the trick. Thank You!
thank tou!!!! worked!!!
Awesome , worked :) thanks man
This might sound ridiculous but it works like a charm. Gratitude.
I had the issue today I found that my alt key was stuck
ˆ ˙å∂ †˙´ ˆßߨ´ †ø∂å¥ ˆ ƒø¨˜∂ †˙å† µ¥ 嬆 ˚´¥ ∑åß ß†¨ç˚
The 2nd line is what results when holding down alt while typing and that is what I was having issues with. Very strange only occurred on my external keyboard and not the laptop keyboard so I figured I had a setting messed up but to no avail.
long press your the ALT KEY in your keyboard and try to type something, it should work properly
Finally I found the answer
Thank you Jordan
My issue isn't solved. When laptop keys are working its typing some wired characters and sometime it just stop working at all. I mean it can't type anything. Just keep getting sound tan tan tan on pressing any keys. Don't we have permanent solution for this issue?
It works to me... Excelent clue!!! The Option/Alt Key was Stuck. When the boot up stars, appeared HD symbol, obviously because the Key Option/Alt stucked. Solve the Problem. Thanx a lot!!!!
It sounds like your "a" key has been remapped to display the symbol it does instead of the "a" you want somehow (via prank, glitch, cosmic event, flying monkeys....).
What is the delete key doing? Maybe it's related, or can be similarly fixed.
I found a Mac key mapper here: http://www.macupdate.com/app/mac/12004/d... but since I do not have a Mac, I cannot test it to see if it'll let you remap your "a" key. Reviews are mixed, proceed at your own risk. Maybe try and find an alternative program if you wish.
mykeyboardhasaproblemwithoneofthekeysifyoucanguesswhicone?lol
i also got problems with this for two days. upon reading your answers guys my problem was solved ;). prior to these weird nordic texts appearing after 30minutes upon boot. all i know ws my left shift key is not functioning so voila yes indeed my shift key was stuck so i have it remapped using karabiner to always ‘increment to brightness’ that’s the only thingi can think of becasuse of you use other like mute it always mute your mac, so thats the best option
I am failed to understand why the customer is built in keyboard of my MacBook types like this
I did command +option +R+P plus power button pressing. No result
Changed languages, no result. Set language as English, no result.
Everything was fine earlier before I stuck due to lockdown for 6 months.
Please help me fix it.
The two behaviors (å and deleting words) indicate you have a stuck option key.
Could be a dirty keyboard. Try another external USB keyboard, or snap both option keys with a fingernail.
Also, the option key may be stuck in software because of accessibility “sticky keys” feature.
If it is, you may have an option key logo in gray in the top right corner of your screen.
Go to
System Preferences > Accessibility > Keyboard > Hardware
and make sure “Enable Sticky Keys” is not set.
For good measure, if it’s not set, set it and unset it again.
Robert Elliott crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 106,600
