Extreme low screen brightness
I cannt see anything on the screen clearly.I conneted the labtop to a projector and adjusted the bightness to 100% but still nothing changed when i disconnect it from the projector
If your laptop screen is very dim or unclear even at 100% brightness, the issue is likely hardware-related. Since it displays fine on a projector, your GPU is working. Common causes include a faulty backlight, damaged LCD panel, or loose display cable. First, restart and check brightness using keyboard shortcuts. Update display drivers to rule out software issues. Shine a flashlight on the screen—if you faintly see content, the backlight is failing. Try gently adjusting the screen angle in case of a loose cable. If nothing improves, you’ll likely need a screen or backlight replacement by a technician.
Oola francis crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 107
