xmas light buld testing
Can the meter be used to test for a bad xmas light in a string of lights?
Yes, you can use an iFixit multimeter to find a bad bulb in a string of Christmas lights.
The two main ways are continuity or resistance:
Continuity:
- Set the multimeter to continuity (the diode/beep symbol)
- Unplug the string from the wall
- Remove a bulb and touch the probes to the two wires inside the socket
- A beep = that section of the circuit is good
- No beep = the bad bulb is somewhere in that section
- Work your way down the string, halving the section each time to narrow it down
Resistance:
- Set to ohms (Ω)
- Same process — test across each bulb's socket
- A good bulb shows low resistance
- A bad bulb shows OL (open line / infinite resistance)
  • You can also test each individual bulb instead of the socket using the same method just touch the probes to the light bulb leads
Here is a video a beginners guide to the iFixit multimeter if needed:
https://www.youtube.com/watch?v=oI_CJA31...
Stan crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 78
crwdns2959996:0crwdne2959996:0 233
