Booting up to a no entry sign... OCLP?
I have a 2012 MBP 13" here that boots upo to a no entry sign, we have tested with 3 HDD Cables and swapped a known good SSD with a clean install of Catalina on it, to no avail. We can safely rule out a cable issue, SSD, HDD, or RAM as all are good. I cannot get into boot options or diagnostics either so I am thinking this may have been patched with OCLP before as the previous owner has kept the SSD from it and they don't respond to any questions asked (They don't know)..... If my assumption is incorrect, any ideas what we need to look into as I have tried just about every other option....?
If your Mac starts up to a circle with a line through it
Are you able to boot up under a clean supported macOS? Then modify this external with Open Core?
@danj Already stated a clean installed SSD..... Zero options at boot also..... If it is indeed OCLP related then a real headache to detect which OS it was patched to....But yes, needs to get back to the last working system whatever that was, then remove the post root patches, then wipe and install HS or Catalina anew.....Maybe HS to Catalina update will get me the 10.15.8 installer IF it exists :D
