Release date: Jan. 24, 2008; 8MP, 3x Optical Zoom, Built in optical image stabilizer system and Face Detection software; DIGIC III Image Processor.
crwdns2934055:0crwdne2934055:0
service manual about fuses check
Hi somebody,
My canon was dunked in water and after drying it out the camera makes no function...
how many fuses are and where they are?
Thaks,
Vidma
vidma, the image will show you where the power fuse is located. Just remember that with water damage, a good cleaning with isopropyl alcohol is a must. Otherwise, you run the risk of corrosion failure later on. Here are more reason why your camera may not get any power:
"If electrical conduction is not found:
• FUSE is blown; replace it with a new one.
If the FUSE is not faulty:
• MAIN PCB Assembly excluding the FUSE is faulty
• OPERATION FPC Assembly is faulty
• TOP COVER UNIT is faulty
• BATTERY COVER is damaged.
• DETECT SWITCH(MAIN PCB assembly) is faulty"
Hope this helps, good luck
Hi oldturkey03 I replaced the main then also cam is not getting on.where can I get all cam spares.plz help
canon sd 1100 got dunked in juice , cleaned with ip also replace fuse 1001 then also not getting 8n plz help.
crwdns2942667:0crwdne2942667:0 1,259
