How do I replace a thermostat?
Where is the thermostat located and how do I replace it?
What is the engine size and which thermostat do you need to replace?
Reason for asking is the 2.5L engine has 2 thermostats whereas the 2.0L engine only has 1.
It's the 2.5L. I believe its the main engine thermostat, since its the one that works with the heater core. I currently don't have heat in the car and was advised that this is most likely the reason.
The video in the blue link above shows a thermostat in the engine block being replaced at 3:26 minutes
@jayeff Thank you. I'll check it out.
crwdns2936753:030crwdne2936753:0 50
crwdns2942667:0crwdne2942667:0 446
