Repair guides, disassembly, and troubleshooting information for the Logitech MX Anywhere 3S portable wireless mouse. Released in December 2023 and identified by parts numbers 910-006925, 910-006926, 910-006927, or 910-006928, depending on color. Successor to the MX Anywhere 3.
Left button not working
The left button intermittently works and has been getting progressively worse over time. Should I follow the disassembly steps as described to replace the battery and try and clean the buttons with compressed air?
Hi @mcfb, if the Logitech MX Anywhere 3S is still under warranty, I recommend sending it in for repair. Based on my experience, once the warranty has expired the usual fix is replacing the microswitch. The part commonly used is an Omron D2FC-F-7N or similar, which requires desoldering the old switch and soldering in the new one.
Thanks @augustine, I'm chasing warranty - I'll see how that goes first. Thanks for the help.
Is this a common problem with this model?
I have the same problem with left click, i'm going to try to repair the button. (Tape was not the issue, it was 100% the button malfunctioning)
This can't be true, those switches are substantially larger than the ones present in the MX Anywhere 3S
mcfb crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 37
crwdns2936753:030crwdne2936753:0 145
crwdns2959996:0crwdne2959996:0 1,056
