Hard Drive not detected!
I currently have an 80 GB sata hard drive and I bought an Hitachi 320 Gb sata drive to upgrade it with, but the laptop doesn't detect the drive, not even in the bios! It's brand new, and if I connect it using a USB adaptor, the drive shows up on my computer. The Bios has been updated to the current version. I'm at a loss, please help!
Thanks!
crwdns2944067:09crwdne2944067:0
Wade Lodge, give us the model or serial number for both of the drives.
80 GB - Western Digitial - S/N: WXE508HR5459
320 GB - Hitachi - S/N: 333ATAHS
Thanks!
I would think that you are having a interface issue here. Especially since your computer reads the drive when it is connected via USB. What are your BIOS settings for the HDD. I am sure you already checked this, but make sure the SATA channel is turned ON in the BIOS. Second, you need to either install the RAID drivers when prompted or set the controller to ATA compatible in order for the OS disc to see an SATA drive. I know from one of your previous posts that you did the last part. Any chance you have a desktop or other computer that supports a SATA drive where you could install the HDD and see if it functions with the SATA interface?
I tried it on an Acer desktop and it was detected, but before that I tried it on another Dell laptop, an Inspiron 6400, BIOS verse A13 and it wasn't detected there either! The only option in this BIOS relating to SATA was called Serial ATA DIPM, which was enabled. I also tried it disabled. Wasn't detected either way. Is it something to do with the Dell BIOS?
It sure does look like it. Your drive is recognized in USB mode, and on other computers but not the Dell, which leads me to believe it is the BIOS. I wonder if it does not support the interface
crwdns2934275:04crwdne2934275:0
crwdns2933315:010crwdne2933315:0
The new drive is probably to fast and needs to be jumpered down to probably 1.5 GB per second. Do a web search for "jumpers & your drives model number".
This model doesn't have jumpers.http://www.hgst.com/internal-drives/mobi...
I bought wd3200lpvx to substitute my dead hdd on my dell inspiron 1525. When I changed it I had the exact same problems. I tried changing BIOS settings, etc but nothing worked.
Solution:
What worked is trying to put the HDD in the laptop without using the drawer/case where you put the disk before inserting it in the laptop. After several tries I managed to put it in the SATA (when I managed to put it, it couldn't move easily as it was attached to the SATA port). Then the HDD was detected normally.
So the case is clearly the 9.5mm vs 7mm of height and there is no mechanical trigger. It's just that the 7mm height disks on the drawer won't attach to the SATA port.
My doubt is if I should leave it like this (without screwing the disk though) or to buy another 9.5mm height disk.
This is exactly what was happening with my HDD, it was a thin one and wasn't lining up with the Sata/Power connector inside the unit. Tried seating it without the drawer and success it could see the device. Thanks for the info.
@bainjack now what is the progress do you have any problem without drawer, because same issue i have faced and solution is totally unacceptable .....how much time you have without drawer plate seated the internal HDD
I just taped a couple of old credit cards to make up for the thickness difference, this way I avoided dismantling my 7mm SSD case. It inserted tight this time. Then I could intall my Linux Mint OS and make my Dell E6520 screaming again.
Thank you, stsr505089, for figuring out an issue with a thickness of the hard drive.
I was replacing a dead hard drive in Dell Inspiron 1525 and fell with the same issue: for some reason BIOS does not recognize newer thin 7 mm hard drives so you have to get a thick 9.5 mm hard drive as a replacement. So i had to buy one more new hard drive that is 9.5 mm thick. Hopefully, now everything is up and running.
That's pretty odd.
When i inserted the first new hard drive that turned out to be a 7 mm in thickness, I checked how it's seated by unscrewing the small bottom cover (that gives you access to memory modules) - the hard drive contacts were inserted into the interface slot, but despite that it was not recognized by BIOS. So that really looks like there is some mechanical switch or something that prevents using thin hard drives. Pretty bizarre solution from Dell.
Try inserting 1-2 credit card thick spacers--worked for m.
Thanks alot, I followed your advice and it worked.
Hi, try to go to the BIOS settings and check what is the SATA settings. If it is in AHCI try to change it to ATA and vice versa if it is set to ATA and then save the settings before exit. You will have to change the Cache Module to OFF before you can change to ATA.
I tried that already, but I'll give it another try. I'm reluctant to reset the Bios to default, do you think that might help?
Tried switching from AHCI to ATA, used no luck. I also chose "load defaults" in the BIOS, and Hard Drive still not detected. Any other ideas?
Thanks!
Remove the drive and reinsert it making sure that it is fully seated. Use firm and even pressure to slide the hard drive into place. Excessive force may result in damage to the connector.
Also, try to reattached your old drive and see if it is detected.
I've tried reseating several times, no luck. I put my 80 GB back in and it works fine. In fact, its what I'm using now.
Bizzarre as it may seem, if you pack up the drive to similar thickness as the one that works with some card or something, you'll find it works,or it did on mine. I think there is a physical switch that needs to be made inside for it to detect the hard drive, and a thin one doesn't make it
It seems like your laptop doesn't supports hard drive of more then a specific size. You can try a smaller hard drive if you have in spare. Because if your hard is working fine on usb and its only the motherboard then its defiantly the compatibility issue.
I found that there's enough slop at the rear of the drive tray opening that the drive was sliding in and just slipping below the drive connector - which I only discovered by removing the main cover panel from the underside of the laptop. Once I could see what was happening, I was able to tilt the drive up using the moulded edge cover and slot it straight in. Before that, sliding the drive in there was a convincing sense of resistance and then applying a bit more pressure it seemed to slot into place. The moulded outer cover even seemed to align well. Rebooted and drive is now recognised. Another "check the power supply first" moment!
Very interesting idea on the thickness of the drive. I have the Inspiron 15R (5537) and was using a Samsung 840 EVO disk without a problem until I upgraded to Windows 10. I suspect that upgrading to Windows 10 had nothing to do with the problem. But, moving the SSD in and out of the laptop to do backups may have caused a problem with the seating of the disk. Since then I have tried a zillion reboots, boot settings, etc with no luck. Tomorrow, I will try to add something to the thickness of the SSD and see if that works. The SSD works fine on USB. I also tried a different 840 EVO SSD in the laptop with the same results. Driver and BIOS updates from Dell didn't help. I'm running out of options but I really would like to get the SSD working because it re markedly speeds up the system.
I couldn't wait until tomorrow to try this. I added a couple of pieces of cardboard to the bottom of the disk compartment. The SSD works great now. I sure wish I had seen the post above about 40 hours ago. As I mentioned above, I had tried just about everything. Kudos to whoever discovered this problem...
I have the exact same problem, I had to use a 2 mm expansion bracket, typically comes with solid-state hard drive's or somewhere on eBay. Worked fine after that
Hi,
My Dell Inspirion N4010 working smoothly, just next morning when I switch on NO Hard drive detected and go to PXE ROM msg and not boot due to no OS found. BIOS version I think needs to be updated as shows A08 where current version is A13. but since this BIOS file is EXE not even able to run from DOS.
Please suggest what to do ASAP.
Thanks and Regards,
Santosh (santosh.ghosh9999@gmail.com)
this is an old post but im posting this in case anyone else is having problems and cant load an OS on the inspiron 1525. laptop. you need to find the dell usb recovery tool its driver which you put on a usb drive change your system to boot in usb mode start up let the tool/driver load then change to load from cd/dvd and you will find it should load ok
Wade Lodge crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 33
crwdns2959996:0crwdne2959996:0 45,791
