Why is my element not working
What's your make and model number?
If your heating element isn’t working, it could be due to several common issues. Here’s a quick guide:
  1. Burnt-Out Element:
    • The element itself may be damaged or broken. Look for visible breaks, blisters, or discoloration.
  2. Faulty Power Supply:
    • Check if the appliance is getting electricity. A tripped breaker or blown fuse can prevent the element from heating.
  3. Defective Thermostat or Control Board:
    • Some appliances won’t send power to the element if the thermostat, thermal fuse, or control board is faulty.
  4. Loose or Damaged Wiring:
    • Wires connecting the element might be loose, burnt, or corroded, preventing current flow.
  5. Test the Element:
    • Use a multimeter to check for continuity. If there’s no continuity, the element needs replacement.
Smells a lot like an AI-generated answer to me... just sayin'...
Himost 15L crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 64
