The Lenovo Thinkpad E15 Gen 2 was released in 2020. It can either have a 11th generation Intel Core i3/i5/i7, or feature a AMD Ryzen 4000 series CPU.
Charging port doesn't work.
Charging port doesn't work anymore with any charger, if I put it in a certain position it works, but rarely.
When a charging port only works at a specific angle—or intermittently—the issue is usually mechanical or contact-related, rather than a problem with the charger itself.
Common causes include:
Debris or Lint Inside the Port - Pocket lint, dust, or corrosion can accumulate inside the charging port and prevent proper contact. This is the most frequent cause.
Worn or Bent Connector Pins - Repeated cable insertion can loosen or deform the internal pins, leading to unstable charging unless pressure is applied.
Loose Charging Port Assembly - The charging port may be partially detached from the logic board or flex cable, especially after drops or liquid exposure.
Recommended steps:
  • Power off the device and carefully clean the port using compressed air or a non-metallic tool (such as a wooden or plastic pick).
  • Inspect the port with a flashlight for visible damage or corrosion.
If cleaning does not resolve the issue, the charging port assembly likely needs replacement.
Adrian crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 85
crwdns2959996:0crwdne2959996:0 498
