The Husky Air Compressor H2G3TK is a portable, corded electric air compressor with a 2.0 HP motor, 2.6-gallon tank, and a maximum pressure of 135 PSI. This page provides detailed information and repair guides for this compact, 30 lbs compressor, suitable for light-duty tasks and equipped with control regulators.
Compressor doesn't start?
Give the replacement motor part number which isn't listed. But the motor is shown. Thanks πŸ‘ 😊
On the diagram this
would be a pressure switch. That would be the second thing to check after the on/off switch. You should be able to see resistance on the 2 terminals of the power plug with the on/off switch on. If not, short out the pressure switch and see if resistance shows - it should be relatively low, 1-5Ξ©.
If there is no reading then you might have a bad motor. Try reading directly on the motor leads.
BAsically.
Troubleshooting the Motor:
If the motor doesn't start, common checks include:
  • Confirming proper power supply (breaker/fuse).
  • Checking for proper extension cord use (avoiding overly long or thin cords).
  • Letting the motor cool down if the thermal overload has tripped.
  • Issues with the pressure switch or internal components like reed valves or brushes if it runs but doesn't build pressure.
Could also be a bad capacitor....
crwdns2957956:0crwdnd2957956:0crwdne2957956:0 crwdns2950251:0crwdne2950251:0
SON'S 360 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 50
crwdns2959996:0crwdne2959996:0 374
