crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2935067:01crwdne2935067:0
crwdns2934263:01crwdne2934263:0
H2G3TK
Background
The Husky Air Compressor H2G3TK is a portable air compressor. It features a 2.0 HP motor and a tank capacity of 2.6 gallons. The power source for the compressor is corded electric, and it has a maximum pressure of 135 PSI. The air delivery rate is 2.0 SCFM at 90 PSI, and the noise level is 78 dBA. The dimensions of the compressor are 17 x 17 x 19 inches, and it weighs 30 lbs.
This air compressor is suitable for light-duty tasks such as inflating tires and operating small air tools. The compact size of the compressor facilitates its transportation and storage. The direct drive pump enables a maximum pressure of 135 PSI. The motor, which is rated at 2.0 HP, is reliable and is equipped with automatic thermal overload protection to prevent overheating. The design of the oil-free pump eliminates the possibility of oil contamination of the compressed air. The tank, which has a capacity of 2.6 gallons, allows for longer run times between refills. The regulators on the unit enable users to control the air pressure and air flow. The compressor also features a carry handle for added portability.
Technical Specifications
  • Power Source: Corded electric
  • Motor: 2.0 HP
  • Tank Capacity: 2.6 gallons
  • Max Pressure: 135 PSI
  • Air Delivery: 2.0 SCFM @ 90 PSI
  • Noise Level: 78 dBA
  • Dimensions: 17 x 17 x 19 inches
  • Weight: 30 lbs
Warranty
The Husky Air Compressor H2G3TK is covered under a 1 year limited warranty. This warranty protects against defects in materials and workmanship from the date of purchase, for a period of 1 year. However, it should be noted that the warranty does not cover normal wear and tear, nor consumable parts. To claim the warranty, it is necessary for users to provide proof of purchase and the date of purchase.
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2942667:0crwdne2942667:0 593
