Phone is not turning on
I just replaced my LCD Screen and the phone isn't turning on after a day
You said "after a day"; does that mean it turned on for some time after the screen replacement?
Just to clarify, are you sure the phone isn't turning on, or is the screen just black? Does it vibrate when you try to power up or plug in a charger?
If your phone isn’t turning on after an LCD replacement, first charge it for at least 30 minutes using a known-working charger and cable. Perform a forced restart (button combo varies by model). Reopen the phone and recheck all display, battery, and power-button flex connectors—they may be loose or damaged. Inspect the battery connector and ensure the battery wasn’t punctured or drained during repair. Look for bent pins, torn flex cables, or missing screws causing grounding issues. Try disconnecting the new screen and powering on with the old screen. If it still won’t turn on, the battery or motherboard may need professional repair.
Angelo crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 9
crwdns2942667:0crwdne2942667:0 20
