2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
Single Graphic Vs Dual Graphic Display Assembly
@danj I have a 2.8 GHz 2015 DG with a faulty display & have found a single graphic 2.8 GHz 2015 model with a good display for cheaper then a replacement Assembly with a 1TB SSD & a near new battery that has just 9 cycles for under $160! I cannot find any info to suggest there is any difference or compatibility issue in swapping over the complete display assembly's. @danj I think your extremely familiar with these as you use one yourself. Need confirmation before I take the plunge and purchase it.
They both use the same screen. It's easy to verify using TheBookYard listings as an example Parts for Apple MacBook Pro 15" Mid 2015
Yes I thought they were the exact same also but just needed confirmation thanks.
Out of curiosity what would make the AMD Graphic kick into action? IF gaming, playing a video, High resolution pictures, external display? I found this video https://www.youtube.com/watch?v=KtpZF22H...
@livfe - The App requests it as the preferred option. This is part of the Apps code framework. There really isn't a need to alter the display setting from a user perspective. If that was needed that would be a crappy App to have not have the setting set, or someone coding an App who needed to see the difference.
@danj Yes, I didn't play with anything from this video, just curious what causes it to switch from Intel to AMD.
@livfe - Don't press the Red Button! 😂🤣😂🤣😂🤣
livfe crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 84
