fans on nothing on screen no beep
when i power my iBook the two fans are on , led on front is on , but no beep , nothing on screen.
the mac will heat normally as it is working, it seems it is always in sleep mode.
i removed the battery and power up with ac adapter but same problem.
Help
Rana
First let's clear the PMU 1. Step 1 Quit all of your active applications and shut down your Mac. 2. Step 2 Once your computer is completely shut down, disconnect the computer's AC power Adapter and remove the battery from your Mac. 3. Step 3 Press and hold down the power button on your MacBook or MacBook Pro for at least five seconds and then release the power button. 4. Step 4 With your Mac still shut off, reinstall the battery in your MacBook or MacBook Pro and reconnect the AC Adapter. The PMU/SMU has now been reset on your computer. Does it start up?
Next we'll zap the PRAM. Hit the start button, hold down the option & command --P & R keys wait till it tones three times then try to start up. Please let us know the results so we can proceed. Thanks
Good answer +
i have the same issue and these steps did nothing for me. I'm thinking its a logic board videoc ard issue.
haddad crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,481
