Part of the 15 series in Dell’s Inspiron notebook line, the 3520 model was released on October 18, 2012. The Dell Inspiron 3520 is a 15 inch laptop that is both affordable and capable of meeting a variety of needs.
Why the screen of my laptop turned white?
How can I repair my laptop if its screen turns white
  1. 🔍 Possible Causes
- Faulty Internal Monitor Cable (LCD Cable): If the cable connecting the monitor to the motherboard is loose or damaged, the screen may appear completely white.
- Faulty Display Panel (LCD Panel): Damage to the monitor itself can result in white or abnormal colors.
- Projection Problem (GPU): Whether integrated or discrete, any malfunction in the GPU can cause the monitor to lose its signal.
- Overheating or Electrical Shock: This can cause temporary or permanent damage to the display components.
- System Settings or Color Mode: In rare cases, the cause may be settings such as switching to grayscale mode in Windows.
  1. 🛠️ Diagnostic and Solution Steps
1. Restart the Device: to ensure the problem is not temporary.
2. Try an External Monitor: via HDMI or VGA. If it works normally, the problem is with the laptop monitor or its cable. 3. Check Windows display settings:
- Go to Settings > Ease of Access > Color Filters and make sure Grayscale mode is disabled.
4. Check the internal cable: (Requires opening the device; a qualified technician is recommended).
5. If the problem persists: You may need to replace the laptop screen or repair the graphics card.
  1. ⚠️ Important Notes
- If the device is still under warranty, it is best to go to an authorized service center.
- Do not attempt to open the device yourself unless you are experienced in hardware repairs, as the internal cables are very delicate.
📌 In short: A white screen is often a hardware problem such as the cable or the monitor itself, and sometimes system settings can cause it.
My screen once went white mid-Zoom call. I panicked, restarted 10 times, nothing. Ended up being my GPU driver crashing so hard that Windows forgot how to show colors. Updating the graphics driver fixed everything.
Abdul Rahman crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 13
