Right fan spinning after water spill on MacBook
Hello!
I have a Macbook Pro 16" 2021 model. My cat has spilled a glass of water behind the laptop, so a bit of it, I guess few drops went into the fan exhaust on the back.
I immediately turned it off and let it dry. That evening I ordered a screwdriver to take the back off. 2 days later day I took the back off and didn't see any water left, so I turned it on, but after like 30-40 minutes of using it fans were spinning crazy so I turned it off and let it air dry for 3 more days.
Now I did a diagnose and i have the following issues:
- There may be an issue with the Power Port (PPP020)
- There may be an issue with the fan (PPF003, PPF004, PPF001)
But when I turn it on and use normally, even charge it, everything seems to work properly. Also it dropped the charging a few days ago, so I plugged the charging cable off and plugged it back in and it was charging fine again.
I decided to tinker with the fan speed, and what I've figured out is that if the right fan reaches max speed, it won't go down, only if I reboot the machine. The left fan works fine.
So my question is, what are my options to repair? Am I able to fix this on my own? Do I just need to clean something with 99% alcohol, or do I have to switch some component too?
Thanks in advance!
