Guides and repair information for washing machines produced by Samsung Electronics, a South Korean engineering and technology company.
Samsung washing machine ww22n6850qx Not Spinning after spinning
The unit is acting up, when running the washer in rinse and spin mode it works. However any other mode it does the initial spin (probably) to figure out the weight and then fills up with water and begins to move an inch to the right and then an inch to the left and again to the right like it’s stuck but its not… i’ve tried all the fixes I could find online but nothing worked. Will try to upload a video of the issue. Also it spits out a error 3C-P4. It indicates it’s the motor but again it works…
Not an expert on this machine but I had one with similar symptoms and the problem turned out to be the carbon brushes in the motor needing replacement, How old it it? Otherwise I'd be suspicious of the electronic control module, I'm sure someone more knowledgeable on these appliances will have more and probably better advice though. if it IS old, I'd check the brushes. On mine it was not that tough a job, and the brushes for your machine are available on-line, If it's relatively new though, I doubt they are the problem
Hi @marklevsky
Here's the service manual for the washer.
Go to p.33 (36 of 53 pdf) in the manual to see what to check in the event of a 3C4 or 3CP error code.
I assume that this is the error code as there's no mention of a 3C-P4 code in the manual
Mark Levsky crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 22
crwdns2942667:0crwdne2942667:0 22
