How to fix bent port (to the laptop end).
The cord is bent. Will work in a certain position. Otherwise it will not. Anyway I can fix this?
@kit21649 we really would need to know what power supply this is. If it has a common barrel connector, you can replace that one. I would suggest that when you do replace it, cut the wire a bit longer at the connector end. That way you can be reasonably assured that you eliminate broken wires as well. Let u know what power supply this is and if possible post a couple of pictures of the connector with your question. That way we can see what you see. Adding images to an existing question
crwdns2942667:0crwdne2942667:0 16
