The OnePlus 8 is an Android smartphone manufactured by OnePlus, released in April 2020. Identified by model numbers IN2010, IN2011, IN2013, IN2015, IN2017, and IN2019 depending on region.
Not sure of how to calibrate fuel gauge after battery replacement
Hello all, I hope you are well.
I recently replaced my Oneplus 8 battery using an iFixit battery and it was a very successful replacement.
I attempted the calibration using the guide from iFixit and many various sources to calibrate the fuel gauge. That first time, I noticed that the battery lasted a long time in general, and lasted a while at 1%. It died, I plugged it in and when it reached 1% again I turned it on and left it to charge.
This worked well for 1 day - but after a few days, the battery percentage would drop quite quickly to 1% and then last 2 to 3 more hours on 1%. Since then, I have attempted the calibration process a few times but I can't quite get the calibration to stick.
  • Is there anything else I can try or am I missing anything in particular?
  • Could there be any fault with the battery? If so, can I diagnose it in any way?
Any guidance would be much appreciated. I was so hopeful to bring my phone back to life from its poor battery life, but I'm sad to see that it's even worse now :(
I can't help unfortunately, I can only share my experience.
I'm with a iFixit replacement battery for my iphone SE 2022, and since the very beginning (after the calibration) it used to drop abruptly from 20% to 0%. After one year of use, it's in the same condition as the original one after two years of heavy usage.
Thank you for sharing that - so it seems like maybe this is inherently expected with the battery, especially if the condition has dropped to the same as your original battery after only 1 year.
Hassaan-Ul crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 13
