Released September 20, Apple's largest and most expensive 2019 smartphone features a 6.5" OLED display, a triple-lens camera system, and greatly improved battery life. Successor to the iPhone XS Max.
My iPhone 11 pro max battery died and wont turn on
hi i think my battery and bms died or its just draining too fast but it was while charging in my fast charger
If your phone is running long enough go to Settings > Battery and while under charge, take a snapshot of what it tells you post it here so we can see.
Or if you suspect you just need a battery here’s the guide to replace it your self (the guide offers the needed part and tools)
iPhone 11 Pro Max Battery Replacement
Or if that’s a bit daunting seek out a shop that can do it for you
its dead wont turn on but it was on 70% capacity and the bms died i think
@ryanklothk25632 - Given its Age it's likely a dead battery. If the BMS logic is damaged that's circuitry within the iPhone logic board and would need a bit of brain surgery to fix.
If you have access to a USB power meter you should be able to see if the phone is even trying to charge or if you have a Mac system using CoconutBattery Plus version you should be able to see more information from the phone.
ryan kloth køie greve crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 36
