nothing happens when I connect the charger
I found this pair of headphones at a flea market. I opened them and found this improvisation on the power jack. Can you tell me if it was done correctly? I also replaced the battery because it was no longer good and the headphones work but when I try to connect them to charge nothing happens.
Sounds like you’ve done some solid detective work already.
crwdns2934271:0crwdnd2934271:0 lucy taylor crwdne2934271:0
@dani88790 post a better picture of the USB board. What is the voltage at the solder points on your headphones circuit board, when you plug your charger in?
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
@oldturkey03 The voltage is 5.12 at the solder point of the bord of jack an same on the solder on the headset bord
crwdns2934271:0crwdnd2934271:0 Dani crwdne2934271:0
@dani88790 I wonder if your charging circuitry is "not turning on" When you connect the charger, what voltage do you get right on the battery connector? If that voltage does not increase when you connect the charger, you know that there is something that does not tell the power management IC to let the battery charge
@oldturkey03 thanks for this tip. when I have time I will test this suggestion and leave the result here
