Discover repair information including guides and tips for Whirlpool Refrigerators. Our comprehensive resources offer detailed instructions for troubleshooting and fixing common issues in various Whirlpool refrigerator models.
Whirlpool refrigerator . Frezer not freezing enoughh
I got refrigerator from whirpool Arc8140/1/lx
But it stop freezing like it's little cold in freezer but not enough I can't change on panel to set degrees c' to be -18 on the bottom line only showing --- what that could be here I attach some pics
this might help
The --- indicates the freezer is not up to temp - which is your stated problem.
How about the fridge? If neither is cooling, then it is likely a control board or sealed system/compressor issue. If just the freezer, check for ice buildup on the coils. That may be caused by a bad freezer door seal or something holding the freezer door open even slightly.
Top it's working fine only bottom freezer not working well it shows doors are closed on the panel it's dosent show degrees on panel just 3 lines --- where the frezer is. There no ice at all cuz it unfreeze everthing it's clear
Rafal Cedro crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 22
