Everything works, but no sound.
TEAC LP R550USB sound system. Record player, cd, cassette, mp3, built in speakers.
4 years old. Only used it briefly 3 times. Just tried to play it and everything works except the sound.
@jhord29092 you've checked the speaker setup as well as all the settings etc.? What have you checked? Since all of those device connect to a common amplifier section it stands to reason there might be issues with that. We just need to rule out any setup issues?
Dearest OT,
This is all one unit. Speakers are inside the unit. Do I need to disassemble it? Honestly, it never moved or was jarred in 4 years….eeeekkkkk
The lights work, you can see different radio stations, cd moves, record player moves, tape deck moves….just no sound. Loose wire inside the unit?
75 yr old Henny Penny
@jhord29092 this does sound more like a settings issue. I just looked through the manual and if you select your source, let's say FM/AM does it select that appropriately and can you turn the volume up? What happens?
I can chose a radio station am or fm and it works correctly. No sound.
