Xiaomi Redmi Note 13 4G Released 2024, January 15 188.5g, 8mm thickness Android 13, up to 15 128GB/256GB/512GB storage, microSDXC
Dropped at the water and he die
My phone if I put it on charge, he take a normal Amber, but when I link it on power supply he gave me 7 to 8 and he still at this situation the accident was he dropped on the water I didn’t find Any oxidation or damage from the outside
Hi @mohammedfa44773
The phone has an IP54 rating which means that it is only dust protected and water resistant, not waterproof
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a video that may help with disassembling the phone so that it can be checked and cleaned as required.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
MOHAMMED FAROUQ MAHER SALEH crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 17
