Why is my laptop not turning on nor charging
My Lenovo laptop would not charge and cut on nut when i plug in the charger the battery light pops up indicating that its charging but its not turning on
@narri24946 Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Next you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. Adding images to an existing question
Of course, you may also have to consider replacing the battery. A depleted battery can no longer be charged. However, it should not prevent your computer from coming on, if it is connected to the AC adapter.
It is also possible that this is a bad RAM module. So, remove the RAM, clean the contacts with a pencil eraser. Do it gentle so as to not destroy the module. Replace it and restart.
Once you have gone through those common troubleshooting and diagnostic steps, and it still did not accomplish anything, we will need to see your motherboard. That way we can try and determine the individual power rails and power distribution, to make determination what part of the charging/power circuity may have failed. Let us know what you find out.
crwdns2942667:0crwdne2942667:0 29
