Comment rėparer un Kymco grand dinck
Batterie inchargiable
Translation
How do you repair a Kymco Grand Dinck?
Battery won't charge
Translation
@abdellaliabbou I assume you are referring to a Kymco Grand Dink scooter. Since you are saying that the battery is not charging, you will need to start off by checking to things. First you need to check the battery and after that the actual charging system. Check the battery according to the manual for the
BATTERY VOLTAGE INSPECTION (OPEN CIRCUIT VOLTAGE)
Disconnect the battery cables. Measure the voltage between the battery terminals. Fully charged : 13.2V Undercharged : 12.3V max
If your battery can't be charged above the minimum required voltage (anything less than 12V) you need to consider replacing it. You can also use a battery load tester to see if your battery can actually deliver the required amperage. The load testers are not very expensive and are a handy tool to have. If your battery fails the load test, it needs to be replaced.
Now, if your battery checks out okay, you will need to test the charging circuit on your scooter to determine if this is a wiring problem, a alternator problem or a rectifier problem. For that use the Battery Charging System chapter from the service manual.
Translation
@abdellaliabbou Je suppose que tu parles d'un scooter Kymco Grand Dink. Comme tu dis que la batterie ne se charge pas, tu dois d'abord vérifier deux trucs. D'abord, tu dois vérifier la batterie, puis le système de charge. Vérifie la batterie en suivant les instructions du manuel pour l'
INSPECTION DE LA TENSION DE LA BATTERIE (TENSION EN CIRCUIT OUVERT)
Débranche les câbles de la batterie. Mesure la tension entre les bornes de la batterie. Pleinement chargée : 13,2 V Sous-chargée : 12,3 V max
Si ta batterie ne peut pas être chargée au-dessus de la tension minimale requise (moins de 12 V), tu dois envisager de la remplacer. Tu peux aussi utiliser un testeur de charge de batterie pour voir si ta batterie peut réellement fournir l'ampérage requis. Les testeurs de charge ne sont pas très chers et sont super pratiques. Si ta batterie échoue au test de charge, il faut la remplacer.
Maintenant, si ta batterie est OK, tu devras tester le circuit de charge de ton scooter pour voir si c'est un problème de câblage, d'alternateur ou de redresseur. Pour ça, utilise le chapitre Battery Charging System du manuel d'entretien.
crwdns2942667:0crwdne2942667:0 24
