Samsung 330 liter frost free double door convertible refrigerator with twin cooling
evaporator fan not stopping twin cooling
The evaporator fan in my refrigerator freeze section not stoping even after compressor stops it only stops when i open the door
That is normal. It continuously runs to circulate air and keep air passing over the temperature probe to more accurately monitor the cabinet temp. Only time that fan should turn off is when the unit enters a defrost cycle, or when the door is opened to prevent excessive amounts of moisture reaching the evap coil and freezing it up.
In other words, this is normal. Not something to be concerned about.
Thank you @brandon_k for the answer
i just felt anxious because it is a new fridge and most of google answer say that the fan should stop.
Google can't be right all the time. I'm a refrigeration tech. You WANT the fans running because then the thermostat can more accurately maintain temp inside the box
mohit lohar crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 44
