Screen gets stuck on start up with linings. (Works sometimes)
Issue:
When I turn on the TV, I’m lucky if it starts properly and works fine. Otherwise, it gets stuck on the RCA startup screen, and I see horizontal lines starting from the top of the screen and moving downward, getting darker as they go.
As I mentioned, if I leave the TV off for a few days and then turn it on, it sometimes works fine — but it’s very random.
RCA makes a lot of televisions. We need to know which model you have. The model number is almost always printed on a label on the back of the TV.
Model is: RHOS651SM
65” smart 4K UHD TV
@indianboy we need to see what those lines look like. You said they get darker as they progress, that would mean it is a power issue with your GATE drives which would be an issue with either your driver boards or your T-con board. We will need to see your boards as well. I would suggest that you check the voltages on your T-con board and see if they are supplying what your panel needs. Of course, always check the wiring as well. Make sure that all ribbon cables are properly seated and no corrosion or tears are present.
Adding images to an existing question
