This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
Help with DS Lite repair - Water damage
Hi everyone, recently I tried fixing up my brother's DS Lite that had stopped working due to water damage a long time ago. When I try charging the DS the orange light briefly turns on then off. I cleaned any residue I found inside with some isopropyl alcohol and used a multimeter to check fuses F1 and F2, EM10 filter and charging port, all seemingly working fine. I came to the conclusion that the battery is fully dead, since I read that the light does that when no battery / dead battery is connected and due to it feeling kinda puffed up to the touch, also I coundn't get any reading off of it with the multimeter. Is there any way to be sure that the battery is truly the issue before I buy a new one? Thanks in advance!
Hi!
Since you have tried to read it with your multimeter (and can’t get any reading from it) there is not much else to do…
I would just get a new battery and test it. If the same issue persist, then return the battery.
Then something did die on the motherboard..
Would try a new battery first and see if that solves anything.
Diogo Haschich crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 42
