The JBL Pulse 3 is a Bluetooth speaker with a light show. The JBL Pulse 3 was released in Spring 2017. The model number for the JBL Pulse 3 is JBLPULSE3BLKAM.
How do I fix water damage on my JBL pulse 3?
Hi, so my JBL pulse 3 accidentally got left in the rain. It’s supposed to be waterproof but now it’s glitching. It turned on for a second and was skipping and flashing lights really fast but just on one side. And then I charged it and now it won’t turn on at all. please help!!
Hi @emergencygirl
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the speaker's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your speaker and then disconnect the battery in the speaker as soon as possible to minimize any further damage.
Then you need to dis-assemble the rest of the speaker and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove any shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the speaker might possibly work correctly again.
Here is the ifixit JBL Pulse 3 repair guide that may help.
If this process seems too daunting, take your speaker to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Emergencygirl crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 30
