The Xiaomi Mi 11 Lite 5G NE is a mid-range smartphone by Xiaomi released September 2021. It has a 6.55" AMOLED display, a 64 MP main camera, a side-mounted fingerprint sensor, a 4250 mAh battery, and runs on a Snapdragon 778G.
How to reconnect screen cable
My xiaomi 11 lite 5g ne sometimes the screen went black and showed green vertical lines. When I pressed near the front camera, the screen worked again normally with no issues in touch or colors.
But after the last time my phone fell, the screen turned off completely. I tried pressing the same spot (this time with more force), and the screen worked again for about 2 minutes, then went black permanently. Now it doesn’t respond no matter how much I press.
Could this mean the display cable got disconnected? If yes, how can I fix this problem?
This sounds like a problem with the delicate connections between the glass that the display circuits are printed on and the flex cable leading to the motherboard. Unfortunately, those connections are not considered repairable (at least, not without equipment costing several thousand dollars), so the only real solution is to replace the screen.
This guide shows how to replace the screen+frame assembly on your phone.
Manuales / Xiaomi Mi 11 Lite 5G / Fullscreen - Nadie Me Llama Gallina
unknown account crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 60
