15.6” FHD 144Hz laptop with Intel i5-13450HX, RTX 3050 6GB, 8GB DDR5, 512GB SSD, Windows 11, 60Wh battery, and 170W adapter.
The laptop not turning on and not charging
when i connect the adapter no charging
no turning on
i replace the adapter but same problem
i charge the battery using another working laptop
the battery was charged but the dead laptop not turn on
@hadidiginet if it does not turn on with a known-well charged battery, you will need to do some power rail checking on your motherboard. It could be as simple as a bad power button to as complex as multiple failed components on the motherboard.
Now, for you to check your circuity, we will need to know the exact model of your motherboard. To work on the motherboard, use this Lenovo LOQ X90 Hardware Maintenance Manual The motherboard model will be printed directly on the board. It is usually around the RAM memory slot. Let us know what that number is (It could be a LA-N221P). Then we have to hope that schematics are available. Right now, just having done a quick search, it appears as if schematics are not yet available in the public domain. That would mean you would have to use a multimeter and check common components etc. Just in case, you also want to post some really well focused pictures of your motherboard (both sides) with your question. That way we can see what you see. Adding images to an existing question
The bord model LA-N221P rev:1a
If you have a schematic plz send to me
The most probable cause is a motherboard power circuit failure (often the DC jack, charging IC, or MOSFETs on the board).
If it was just RAM or HDD, the laptop would power on but not boot (fans, lights would start). Since it’s completely dead, the power delivery path on the motherboard is almost certainly faulty.
hadi diginet crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 71
crwdns2942667:0crwdne2942667:0 156
