How should I fix the Xbox One system error E100?
Hey, guys, my Xbox One device encountered an error after an upgrade, and then I found that the 1t mechanical hard drive inside was damaged. I replaced a new 500G solid-state drive in, but after turning it on, the error code E100 0000070D 80070002 appeared I tried several troubleshooting methods. I used a USB flash drive to download the offline system (OSU1) for manual update. When the update progress bar reached 3/1 (download completed), the error E101 90060007 8B05000F was displayed and the update could not continue.
Also, I refer to the Install firmware on Xbox One S this post using a script to install the system directly to the hard On the disk, the process went smoothly, but after reinstalling the hard drive back into the machine, nothing happened and the E100 error still occurred.
Are there any other ways? I need some advice and help. Thank you
Hi!
Which SSD brand did you installed??
Are you sure that the OSU you have downloaded is the newest version you can get? Because the E101 indicates that a older version is trying to be installed.
The E100 error actually points that it can’t update because of a hardware failure. This means that if the disk drive is broken, it also could show this error. Make sure that disk drive is OK, as well as the ribbon cables.
If above of them are all OK, you could try a other HDD and see how that goes. Make sure that you do run the script and make sure that it’s partioned corectly. Leave everything empty and use a USB device NTFS formatted with the newest OSU (offline update) and try again!
Please let us know how it goes!
I took my Xbox to a repairshop and he says the same thing is happening, he said this is happening because Xbox has not uploaded the latest OSU into their website, if you fix it please let me know.
夏夕空 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 109
