My laptops back top right screw is not coming off .
the top right screw is not coming off I have tried pulling out magnet but no progress it's just spinning
Can you get a rubber band or piece of string under the screwhead and lift it up?
If no good, put some supa glue on the end of a QTip and then hold it onto the screwhead until it sets.
Don't use too much as you don't want it to run down over the screwhead down the hole into the cover etc.
When it has dried, use the QTip to gently turn the screw (to unscrew it) whilst pulling it up out of the hole
To avoid causing damage to the lid, you may have to resort to getting either screw extracting pliers or screwdrivers (examples only).
Only other option that I can think of is to tighten the screw (if possible) and then drill the screwhead off with a drill bit the same size as the head and then lift the cover off and use pliers to unscrew/remove the remainder of the screw.
crwdns2934075:0crwdne2934075:0
$24.99
$19.99
Didn't worked the qtip isn't even sticking to it I tried with a screwdriver i was gently unscrewing it while pulling up still didn't worked
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 44
