A gaming PC is a personal computer specifically designed and optimized for playing video games.
Pc powering on then after 30 seconds shuts off
When I got a new gpu plugged it in then realized I didn’t have a power supply enough for it but then then got the power supply and turned it on but now it’s power cycling and I have tried everything
Hi @stephenspellman
Can you try using the original GPU card in the PC and see if now works OK?
You may have internal damadge already on the PC.
A. Test with onboard gpu ( if it has one. )
B. Test with everything pluged out - see if it holds power (and cpu/case fan- runs).
C. Check for short on main coils, caps and mosfets. (if no short - checking with ohm meter detected, > go to D:)
D. Test motherboard / PC setup outside case.
It can be short from MB to case , internal short of a component or worse, motherboard.
The shut-down after a few seconds usually means it's entering a protection mode becauase of a fault on one(or more) of the main rails(12v/5v/3.3v/1.x)...
In rare instances can be the bios.... (corruption or not enough voltage at v3.3/1.8)
(if it was a bad assembley or bad part's mounting some smd-parts may have come loose , so it's wise to check for this visually).
Stephen Spellman crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 34
