The Xiaomi Redmi 9C is a low-budget smartphone by Xiaomi released June 2020. It has a 6.53" IPS LCD display, a 13 MP main camera, a 5000 mAh battery, and runs on a Helio G35.
Cara memperbaiki hp yang tidak bisa terisi saat di cas
Tolong beritahu saya cara memperbaiki hp yang bisa terisi daya
Translation Indonesian - English
How to fix a phone that won't charge when charging?
Please tell me how to fix a phone that can charge.
@ranggamunir not charging and not holding a charge are two different things. It will be helpful if you give us more details. We will need to know exactly what it does when you try to charge it. In the meantime start off by testing the easy things.
First check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. IF not then the issue is either the port or the charging circuit.
Since iFixit does not yet have a specific guide for this, use the ones from here Those are written in Spanish. Use a browser that does the translation for you, if needed.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Translation
Tidak mengisi daya dan tidak menahan daya adalah dua hal yang berbeda. Akan sangat membantu jika Anda memberi kami detail lebih lanjut. Kami perlu tahu persis apa yang terjadi saat Anda mencoba mengisi dayanya. Sementara itu, mulailah dengan menguji hal-hal yang mudah.
Pertama, periksa pengisi daya Anda. Pastikan output-nya sesuai. Kemudian, periksa kabel pengisi daya Anda. Pastikan konektor tidak bengkok, dll. Setelah itu, periksa port pengisian daya. Bersihkan dari kotoran, dll., gunakan beberapa semprotan udara untuk membersihkannya. Jika tidak ada yang berhasil, gunakan amperemeter USB dan periksa apakah ponsel Anda menarik arus listrik dari pengisi daya. Jika tidak, kemungkinan masalahnya ada pada port pengisian daya atau baterai yang rusak.
Untuk memeriksa port pengisian daya, gunakan voltmeter dan ukur tegangan pada konektor baterai Anda. Selanjutnya, colokkan pengisi daya ponsel Anda. Sekarang ukur tegangan pada konektor baterai Anda. Tegangan tersebut pasti sudah meningkat. JIKA tidak, maka masalahnya ada pada port atau sirkuit pengisian daya.
Karena iFixit belum memiliki panduan khusus untuk ini, gunakan panduan dari sini Panduan tersebut ditulis dalam bahasa Spanyol. Gunakan peramban yang dapat menerjemahkannya untuk Anda, jika perlu.
Sambil menggunakan ponsel Anda, ambillah banyak foto. Setelah selesai, ambil foto-foto tersebut dan buatlah panduan untuk iFixit. Panduan ini akan membantu orang lain yang mengalami masalah yang sama dengan Anda. Membuat panduan ini mudah dan menyenangkan. https://ifixit.com/Guide/new Komunitas iFixit akan sangat menghargai panduan ini.
Rangga Munir crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 24
